Laptop Power Management
Power management is a critical thing to understand in laptops. It’s possible to buy an expensive laptop and end up not using it because of bad power management practices.
Also, not taking care of the thermals on a laptop will lead to less laptop life, shorter battery, and unpleasant heat generation.
Cooling Pad
Get any cheap amazon cooling pad from amazon. Here is a decent $30 one with lots of reviews. https://amzn.to/3SV0Y0l
Redo Thermal Paste
By default, almost any and every laptop has excessive thermal compound which leads to higher temperatures. Simply removing the excess compound and apply just a drop of “good” thermal paste will drop temps by about 10 Celsius.
Here is an example of excess factory thermal compound application:
termal
Adjust Max CPU Frequency
Set your CPU governor to the maximum power it can use. I NEVER use a 100% of the CPU and in most instances rarely break above 50% of its total power. Typically, around 2 GHz is perfect for my day-to-day work. When working on battery, I put this down to 25% on a beefy laptop to conserve most of its power. On weaker laptops, you’d probably double these numbers. 100% on AC Power and 50% on Battery.
Linux - cpupower
Required Dependencies
Install the following packages
  • cpupower
  • acpi-support
  • acpid
  • acpi
Example Install:
apt-get install acpi-support acpid acpi linux-cpupower cpufrequtils
Setting Min/Max Power Example
cpupower frequency-set -g powersave -d 0.8G -u 1.2G
Check Frequency
cpufreq-info
Disable Turbo
Turbo will draw more power and reduce battery life while increasing CPU temperature.
Run the following from a root user:
echo 1 > /sys/devices/system/cpu/intel_pstate/no_turbo
Turn off CPU Cores
The more CPU cores that your laptop uses, the power it will draw. On higher end laptops you can see as big as a 75% savings and extend the battery life x3.
Taking a CPU core offline (Note: you can’t offline cpu0)
echo 0 > /sys/devices/system/cpu/cpu#/online
To disable cores above 4 threads, run the following in a bash script:
for ((i=4;i<$(nproc);i++)); do echo 0 > /sys/devices/system/cpu/cpu$i/online; done
Use CPULIMIT to Constrain Apps
Install
sudo apt install cpulimit
Adjust EXEC commands in .desktop
cpulimit --limit 70 /usr/bin/google-chrome-bin
Note: This would limit CPU usage for Google Chrome to 70%
Linux - adjust GPU power
There are two methods for adjusting the power usage your GPU uses. I personally use both depending on the laptop, but eGPU’s will eat up a battery laptop in no time.
Manually adjust MHz of GPU
Set the following variables:
  • /sys/class/drm/card0/gt_max_freq_mhz
  • /sys/class/drm/card0/gt_boost_freq_mhz
Using cat to display current MHz and then simply echo the new lower value to these variables.
Example:
echo "1000" > /sys/class/drm/card0/gt_max_freq_mhz
Turning off GPU with Prime-select
While there are technically 3 options, I recommend only using NVIDIA and intel, as on-demand doesn’t work very well.
Turning off GPU with Envycontrol
Cool python project that rebuilds the init system to exclude nvidia.
https://github.com/geminis3/EnvyControl
Windows - GUI Power Management
Launch the GUI power panel with Start ⇾ Run powercfg.cpl
win-power
Then change the Min / Max CPU Power. I typically set these to 5% Min and 50% Max, but on weaker laptops you can set these higher.
Windows - AutoHotkey Script
This script sets the max CPU state when plugged in to the wall (AC Power) and when it runs on battery (DC Power).
PowerWriteProcessorStateValueIndex(50, "AC")
PowerWriteProcessorStateValueIndex(25, "DC")
ExitApp
PowerWriteProcessorStateValueIndex(Max := "", Mode := "") {
	l:=PowerEnumeratePlans(ActivePlan), VarSetCapacity(GUID_ACTIVE_POWER_SAVING, 16, 0), VarSetCapacity(GUID_PROCESSOR_SETTINGS_SUBGROUP, 16, 0)
	, DllCall("Ole32.dll\CLSIDFromString", "WStr", "{" ActivePlan.GUID "}", "Ptr", &GUID_ACTIVE_POWER_SAVING), VarSetCapacity(GUID_PROCESSOR_THROTTLE_MAXIMUM, 16, 0)
	, DllCall("Ole32.dll\CLSIDFromString", "WStr", "{54533251-82be-4824-96c1-47b60b740d00}", "Ptr", &GUID_PROCESSOR_SETTINGS_SUBGROUP)
	, DllCall("Ole32.dll\CLSIDFromString", "WStr", "{BC5038F7-23E0-4960-96DA-33ABAF5935EC}", "Ptr", &GUID_PROCESSOR_THROTTLE_MAXIMUM)
	, DllCall("PowrProf.dll\PowerWrite" Mode "ValueIndex", "Ptr", 0, "Ptr", &GUID_ACTIVE_POWER_SAVING
	, "Ptr", &GUID_PROCESSOR_SETTINGS_SUBGROUP, "Ptr", &GUID_PROCESSOR_THROTTLE_MAXIMUM, "UInt", Max, "UInt")
	for k, v in l
		if !(v.Default) {
			RunWait, % ComSpec " /c powercfg /s " v.GUID,, Hide
			break
		} RunWait, % ComSpec " /c powercfg /s " ActivePlan.GUID,, Hide
;enumerates all power plans
;for k, v in PowerEnumeratePlans()
;	MsgBox % "#" k "`nGUID: " v.GUID "`Name: " v.Name "`nDefault?: " v.Default
PowerEnumeratePlans(ByRef ActivePlan := "") {
	List := {}
	for k, v in StrSplit(CMD("powercfg /l"), ":", A_Space A_Tab)
		if (A_Index>1) {
			Info := {}, Info.GUID := SubStr(Trim(v), 1, 36), Info.Default := !!InStr(v, "*")
			, Info.Name := Trim(StrSplit(SubStr(v, InStr(v, "(")+1), ")")[1]), List.Push(Info)
			if (Info.Default)
				ActivePlan := Info
		} return List
;executes cmd command and return the result
CMD(CMD := "", Encoding := "UTF-8", ByRef ExitCode := "") {
	DllCall("Kernel32.dll\CreatePipe", "PtrP", hReadPipe, "PtrP", hWritePipe, "Ptr", 0, "UInt", 0)
	, DllCall("Kernel32.dll\SetHandleInformation", "Ptr", hWritePipe, "UInt", 1, "UInt", 1)
	, Size := VarSetCapacity(STARTUPINFO, A_PtrSize=4?68:104, 0), NumPut(Size, STARTUPINFO, 0, "UInt")
    , NumPut(0x100, STARTUPINFO, A_PtrSize=4?44:60, "UInt"), NumPut(hStdInRd, STARTUPINFO, A_PtrSize=4?56:80, "Ptr")
    , NumPut(hWritePipe, STARTUPINFO, A_PtrSize=4?60:88, "Ptr"), NumPut(hWritePipe, STARTUPINFO, A_PtrSize=4?64:96, "Ptr")
	, pi := CreateProcess(, ComSpec " /c " CMD,,,, 0x08000000,,, &STARTUPINFO)
	, DllCall("Kernel32.dll\CloseHandle", "Ptr", hWritePipe), Size := VarSetCapacity(Buff, 4095)
	while DllCall("Kernel32.dll\ReadFile", "Ptr", hReadPipe, "Ptr", &Buff, "UInt", Size, "PtrP", Bytes, "Ptr", 0)
        OutputVar .= StrGet(&Buff, Bytes, Encoding)
	DllCall("Kernel32.dll\CloseHandle", "Ptr", pi.handle), DllCall("Kernel32.dll\CloseHandle", "Ptr", hReadPipe)
	return OutputVar, DllCall("Kernel32.dll\GetExitCodeProcess", "Ptr", pi.handle, "UIntP", ExitCode)
} CreateProcess(ApplicationName := "", ByRef CommandLine := "", ProcessAttributes := 0, ThreadAttributes := 0, InheritHandles := true, CreationFlags := 0x08000000, Environment := 0, CurrentDirectory := "", StartupInfo := 0) {
	VarSetCapacity(PROCESS_INFORMATION, A_PtrSize=4?16:24, 0)
	, r := DllCall("Kernel32.dll\CreateProcess", "Ptr", ApplicationName=""?0:&ApplicationName, "Ptr", CommandLine=""?0:&CommandLine
	, "Ptr", ProcessAttributes, "Ptr", ThreadAttributes, "Int", !!InheritHandles, "UInt", CreationFlags, "Ptr", Environment, "Ptr", CurrentDirectory=""?0:&CurrentDirectory
	, "Ptr", StartupInfo, "Ptr", &PROCESS_INFORMATION)
	return r?{HANDLE: NumGet(PROCESS_INFORMATION, 0, "Ptr"), hThread: NumGet(PROCESS_INFORMATION, A_PtrSize, "Ptr")
	, ID: NumGet(PROCESS_INFORMATION, A_PtrSize=4?8:16, "Ptr"), ThreadID: NumGet(PROCESS_INFORMATION, A_PtrSize=4?12:24, "Ptr")}:0, ErrorLevel := !r
