If you are looking for a Linux distro that is stable, predictable, and easy to recommend to normal people, Pop!_OS 24.04 is not it. The main reason is simple: System76 launched it with COSMIC in beta. That one decision turns what should have been a safe long-term support release into a moving target.
For a lab machine, a spare laptop, or someone who enjoys testing unfinished software, that might be fine. For everyone else, especially new Linux users, that is a terrible trade. An LTS release is supposed to be the version you install when you want fewer surprises, not more.
The Real Problem
System76 has been building COSMIC as its own desktop environment, and on paper that sounds great. More competition in Linux desktop development is a good thing. The problem is not that COSMIC exists. The problem is that Pop!_OS 24.04 ships a beta desktop on top of an Ubuntu LTS base and then expects users to treat it like a dependable daily driver.
That creates a mismatch in expectations:
- People hear “24.04” and “LTS” and expect stability.
- People buy System76 hardware and expect the software to be polished.
- New Linux users hear Pop!_OS recommended and assume it is a safe starting point.
Right now, those assumptions are wrong.
Why A Beta Desktop On LTS Is A Bad Idea
Long-term support releases exist for one reason: reliability. You choose them because you want to install once and stop thinking about the desktop breaking every few days. If the desktop shell itself is still behaving like a public test build, the LTS label does not mean much to the end user.
When the desktop environment is unstable, every basic task becomes suspect:
- Logging in
- Managing windows and workspaces
- Resuming from sleep
- Audio controls
- GPU acceleration
- Multi-monitor behavior
That is not a small issue. The desktop environment is the operating system experience for most users. If it leaks memory, crashes, or has broken display handling, then the distro does not feel reliable no matter how solid the base packages are underneath.
The Bugs Are Not Edge Cases
This is not just a complaint about a rough animation or a missing setting. The issue tracker has repeated reports of serious bugs that affect day-to-day use.
Memory Leaks And Stability Problems
There are multiple reports around runaway memory usage and general instability:
- https://github.com/pop-os/cosmic-epoch/issues/2122
- https://github.com/pop-os/cosmic-epoch/issues/3224
- https://github.com/pop-os/cosmic-epoch/issues/2920
- https://github.com/pop-os/cosmic-epoch/issues/2013
- https://github.com/pop-os/cosmic-epoch/issues/1591
If your desktop session gradually eats RAM or becomes unstable over time, that is not a tiny annoyance. That is the kind of bug that makes a machine feel unreliable even when you are doing basic work like browsing, coding, or streaming.
GPU And Display Problems
Linux desktop success lives and dies on display handling. If monitors flicker, GPU acceleration breaks, or NVIDIA systems act up, many users are done immediately. There are active reports covering those areas too:
- https://github.com/pop-os/cosmic-epoch/issues/3270
- https://github.com/pop-os/cosmic-epoch/issues/3249
This matters because Pop!_OS has historically been recommended to people specifically because it handled hardware reasonably well. If the new desktop introduces display instability, that recommendation gets a lot harder to defend.
Audio And Volume Bugs
Audio problems are another instant deal-breaker for normal users. When volume controls misbehave or sound routing becomes inconsistent, people do not care that the desktop is “still improving.” They just think Linux is broken.
- https://github.com/pop-os/cosmic-epoch/issues/3074
- https://github.com/pop-os/cosmic-epoch/issues/3094
- https://github.com/pop-os/cosmic-epoch/issues/3026
Again, this is the exact category of bug that should not be front and center on something positioned like a polished desktop OS.
Why This Is Worse For New Linux Users
Experienced Linux users can work around a lot. They can drop to a TTY, restart services, swap desktop environments, inspect logs, and recover from bad updates. New users cannot. They install a distro, hit three broken behaviors in a week, and conclude that Linux desktop is not ready.
That is why I have a problem with Pop!_OS 24.04 in its current state. It is not just rough for enthusiasts. It is actively risky as a recommendation to beginners because beginners are the exact people who are most likely to trust the branding around an LTS release.
If you hand a new user a distro with a beta desktop, you are not giving them a stable introduction to Linux. You are turning them into a tester whether they agreed to that or not.
Who Should Skip Pop!_OS 24.04
I would avoid Pop!_OS 24.04 right now if you are:
- New to Linux
- Installing on your main work machine
- Using NVIDIA hardware and want the least drama possible
- Buying a laptop because you just want it to work
- Recommending a distro to friends or family
In all of those cases, stability matters more than novelty.
Who Might Still Want It
There is still a small group of people who may want to run it anyway:
- Users who specifically want to test COSMIC
- People filing bug reports and helping development
- Tinkerers with a backup machine
- Anyone who understands they are effectively running beta desktop software
That is a valid use case. But that is a tester profile, not a mainstream recommendation.
Better Options Right Now
If your goal is a dependable Linux desktop in 2026, I would point most people somewhere else until COSMIC matures.
- Linux Mint if you want conservative and easy
- Fedora if you want modern without chasing a beta desktop shell
- Ubuntu LTS if you want broad support and predictable behavior
- Bazzite if your focus is gaming and you want a more curated experience
None of these are perfect, but they are easier to recommend to normal users than a distro shipping a beta desktop as its headline feature.
Final Thoughts
System76 makes interesting hardware, and I want COSMIC to succeed eventually. But wanting a project to succeed is not the same thing as pretending it is ready.
Pop!_OS 24.04 asks users to trust an LTS release while tying that release to a desktop environment that still shows beta-level problems. That is the wrong move for a distro that many people see as a safe recommendation.
So the simple advice is this: if you want a stable Linux desktop today, skip Pop!_OS 24.04 for now. Revisit it later when COSMIC is out of beta, the major issues are ironed out, and the operating system earns the reliability that an LTS label is supposed to promise.
