Enable Vrr Xorg
Enable Vrr Xorg
This shows you how to enable VRR (Variable Refresh Rate) in Xorg on Linux. This is useful for gaming and reducing screen tearing.
Enable VRR Xorg Conf
Create a new file in /etc/X11/xorg.conf.d/10-amdfreesync.conf
Section "OutputClass"
 Identifier "AMD"
 MatchDriver "amdgpu"
 Driver "amdgpu"
 Option "VariableRefresh" "true"
EndSection
Reboot and you will have it enabled. You can verify your monitor supports VRR with this command: xrandr --props | grep -i "vrr"
You can then verify it is enabled through the log file at /var/log/Xorg.0.log
Example output:
[     8.444] (II) Applying OutputClass "AMD" options to /dev/dri/card1
[     8.444] (**) modeset(0): Option "VariableRefresh" "true"
[     8.444] (==) modeset(0): RGB weight 888
[     8.444] (==) modeset(0): Default visual is TrueColor
[     8.444] (II) Loading sub module "glamoregl"
[     8.444] (II) LoadModule: "glamoregl"
[     8.444] (II) Loading /usr/lib/xorg/modules/libglamoregl.so
[     8.454] (II) Module glamoregl: vendor="X.Org Foundation"
[     8.454]  compiled for 1.21.1.18, module version = 1.0.1
[     8.454]  ABI class: X.Org ANSI C Emulation, version 0.4
[     9.059] (II) modeset(0): glamor X acceleration enabled on AMD Radeon RX 7800 XT (radeonsi, navi32, LLVM 20.1.8, DRM 3.64, 6.16.4-114.bazzite.fc42.x86_64)
[     9.059] (II) modeset(0): glamor initialized
[     9.059] (**) modeset(0): VariableRefresh: enabled
[     9.059] (==) modeset(0): AsyncFlipSecondaries: disabled
[     9.059] (II) modeset(0): Output DP-1 has no monitor section
[     9.059] (II) modeset(0): Output DP-2 has no monitor section
[     9.059] (II) modeset(0): Output HDMI-1 has no monitor section
[     9.064] (II) modeset(0): Output HDMI-2 has no monitor section
