Four years ago, I built this website with Hugo. In August 2026, I deleted the Hugo build, replaced it with Astro, and moved the entire production site without changing the URLs people already use.
Hugo was not broken. That is what made this migration interesting. The site had simply grown from a blog into a publication, video archive, search engine, download hub, newsletter funnel, and a pile of old links that absolutely could not disappear. Rebuilding the easy 80 percent would have taken an afternoon. Preserving the last 20 percent was the real project.
So, was moving from Hugo to Astro worth it? Yes, but not for the reason most framework comparisons give you.
Why Replace Something That Already Worked?
My original website setup was intentionally simple:
Markdown -> Hugo -> GitHub -> Cloudflare Pages
That workflow served me well for years. Hugo is fast, dependable, and still one of the best static site generators available. If you have a documentation site or a straightforward blog, I am not going to tell you to rewrite it because a JavaScript framework has a shinier home page.
But christitus.com stopped being a straightforward blog.
It now has hundreds of articles, category and tag archives, livestreams with synchronized chat replays, local search, downloads, newsletter signup, feeds, comments, ads, analytics, old redirects, and years of Markdown written against Hugo behavior. The Hugo version worked, but every custom feature added another template, partial, shortcode, SCSS rule, or vendor script to a stack that was getting harder to reason about as one system.
I wanted three things:
  1. A frontend I could understand from the page down to the browser behavior.
  2. Tests that proved the old links and content still worked.
  3. A foundation that was easier to change without dragging a client framework into every page.
Astro fit that job. It gives me components and TypeScript at build time, ships static HTML by default, and lets browser JavaScript stay small and local. There is no React application hiding underneath this site. It is still a static website deployed by Cloudflare Pages.
The new publishing path is almost boring:
Markdown -> Astro -> GitHub -> Cloudflare Pages
The generator changed. The static-site philosophy did not.
The Website Was the Contract
The biggest mistake in any rebuild is treating the source code as the product. It is not. The product is everything people and machines can already reach.
Before changing the build, I captured Hugo’s production output as a baseline. That clean build contained:
  • 2,156 generated files
  • 813 Hugo pages
  • 125 paginator pages
  • 244 aliases
That included much more than article HTML. It included case-sensitive URLs, category pages, tag pages, RSS feeds, sitemap entries, social metadata, search records, redirects, images, downloads, and weird historical edge cases nobody remembers until Google lands on one.
One tracked image even had to remain byte-for-byte identical at its old public path. Some old posts had empty categories. Others used historical capitalization that new articles are no longer allowed to use. The archive contained Hugo shortcodes, raw HTML, date-only front matter, timestamps with offsets, and posts where an omitted draft field meant published.
That mess is not bad data. It is a public compatibility contract accumulated over years.
Instead of cleaning up the archive and hoping for the best, the migration taught Astro how to read it. New content gets stricter rules. Old published content keeps working.
Rebuilding Hugo Behavior Without Hugo
Astro content collections now load the existing Markdown with typed metadata. The production build excludes drafts and future posts, but a separate local preview command lets me see them while writing. A repository-owned post scaffolder replaced Hugo archetypes and catches URL collisions before it writes a file.
The compatibility renderer handles the Hugo shortcodes that are actually in the archive, including YouTube, notices, tables, X posts, and Shopify embeds. An unknown active shortcode fails the build instead of quietly publishing broken template syntax. Literal shortcode examples inside code blocks remain article content.
This is the unglamorous part of a successful migration. I did not run a giant search-and-replace across old articles. I built a boundary around the history.
Routes received the same treatment. The Astro build generates and checks the homepage, posts, pagination, taxonomies, search index, feeds, sitemap, livestreams, player pages, legal pages, and redirects. The validator rejects collisions between content, static assets, redirects, feeds, and generated routes.
By the end, the new production artifact had a deterministic 1,183-route compatibility contract and 312 searchable entries. That matters more to me than whether one generator won a synthetic build-speed contest.
I Used the Migration to Delete Frontend Baggage
The Hugo site had grown a traditional frontend layer over time: Bootstrap, Font Awesome bundles, Fuse, Mark.js, Shuffle, theme scripts, Shopify code, SCSS partials, and many custom layout files.
The Astro conversion removed that layer and replaced it with:
  • reusable Astro components
  • one custom CSS token system
  • vanilla TypeScript for interactive behavior
  • self-hosted fonts
  • static pages with progressive enhancement
The result supports dark and light themes, keyboard navigation, local search, livestream browsing, synchronized chat, lazy comments, lazy ads, and an intent-driven store integration. The important part is that a visitor does not download a full client UI framework just to read an article.
Third-party code also stopped being a requirement for the page to function. Search uses a generated local index. The download page retains a direct store link if Shopify is blocked. The livestream player works without chat. Ads, comments, video APIs, and newsletter extras load only when they are needed.
That is the web I want: the content works first, and the integrations enhance it afterward.
Performance Was a Gate, Not a Vibe
Framework marketing loves a perfect Lighthouse screenshot. Real performance work is less glamorous.
The migration added a pinned mobile Lighthouse profile that runs three times on the homepage, an article, a category page, and the livestream archive. During the final review, those pages scored between 99 and 100 for performance, 100 for accessibility, 100 for SEO, and 96 for best practices in the local fallback environment. Median Largest Contentful Paint ranged from 1.58 to 1.95 seconds, with zero layout shift on those runs.
Those results did not appear automatically because the project used Astro. The commit history shows the real work:
  • stabilize Lighthouse performance
  • stabilize mobile listing performance
  • reduce webfont render delay
  • inline the site stylesheet
  • fix the remaining migration review findings
And after launch, I still changed the layout spacing, added missing support paths to search and downloads, adjusted the Lighthouse threshold to account for real run-to-run variance, and fixed the article table of contents so it actually stays pinned while scrolling.
That last part is important. A green migration does not mean the design is done. It means the new foundation is safe enough to improve.
The Test Suite Became the Real Feature
The final Astro build is checked by much more than npm run build.
The repository validates formatting, Markdown, dependency policy, Astro types, unit tests, deterministic output, the route contract, and the production build. Playwright then exercises the site in Chromium, Firefox, mobile Chromium, and WebKit. Browser tests cover the homepage, articles, taxonomy pages, search, downloads, newsletter signup, livestreams, chat and no-chat player states, redirects, the theme switcher, mobile navigation, keyboard access, and the 404 page.
Accessibility checks found a real contrast failure during development. It was fixed before the final run. That is exactly what I want from automation: not a badge, but a specific problem found before users have to report it.
The full clean validation produced a deterministic 1,285-page Astro build, ran 61 unit and workflow tests, exercised 66 applicable browser tests, and completed 12 Lighthouse runs. WebKit ran in its supported Playwright container because the fallback binary did not match my Fedora host libraries.
This is more ceremony than a personal blog needs. It is not more ceremony than a production publication with years of inbound links needs.
The Hidden Migration Was GitHub Automation
The visible redesign was only half the job.
Livestream and chat data had been updated by separate scheduled workflows that pushed generated data. The migration consolidated that pipeline and added guards around the exact commit being tested. Candidate automation changes are limited to the generated data paths, checks attach to the exact validated SHA, and interruption handling can reconcile the branch and pull request instead of blindly starting over.
Nobody watching the video will look at the homepage and say, “Nice immutable commit validation.” That is fine. Infrastructure is successful when it makes the boring failures boring to recover from.
The same rule applied to deployment. The old Hugo output, Cloudflare settings, redirect behavior, and repository state were captured before cutover. A rewrite without a rollback plan is not confidence. It is gambling with extra steps.
What the Commit History Actually Shows
The main pull request contained 23 commits before it was merged. The sequence is more useful than the final screenshot:
write the specification and roadmap
  -> close planning and cutover gaps
  -> capture the Hugo baseline
  -> build the Astro content foundation
  -> build the editorial experience
  -> finish infrastructure and automation
  -> review, fix, measure, and repeat
The merged change touched 175 files, added 49,426 lines, and removed 7,408. A large part of those additions is recorded baseline and lockfile data, not 49,000 lines of shiny new application code. The deletions are more revealing: Hugo configuration, templates, archetypes, old pipeline assets, vendor scripts, and SCSS all left the production path.
The project did not begin with npm install astro. It began with nine planning and review commits that defined what could not break. Only then did the history move through baseline capture, content, design, infrastructure, performance, and final review.
That order is why this worked.
What Got Better
The obvious improvement is maintainability. A page is now composed from Astro components instead of behavior being spread across Hugo templates, partials, shortcodes, and global vendor scripts. TypeScript catches mistakes earlier, and the browser code lives beside the feature that needs it.
The editorial workflow is also safer. A new post command creates consistent front matter, uses the correct date and URL shape, requires a valid category, defaults to a draft, and refuses to overwrite or collide with an existing route.
Most importantly, I can make changes with evidence. If I touch search, routes, metadata, a feed, or the article layout, the repository has a focused way to prove whether I broke it.
What Astro Did Not Magically Fix
Astro did not make historical content clean. We had to model the exceptions. It did not make third-party integrations reliable. We had to build fallbacks. It did not guarantee accessibility or speed. We had to test both. It did not make deployment safe. We had to capture the old state and design a rollback.
It also moved the toolchain from one Hugo binary to Node, npm, a lockfile, Astro, TypeScript, Vitest, Playwright, Lighthouse, and supporting packages. That is a real dependency cost. The new stack is easier for me to extend, but it is not smaller in every possible sense.
If your Hugo site is fast, easy to maintain, and does everything you need, keep it. Rewrites are expensive. A framework switch without a concrete maintenance problem is just a new way to own the same website.
Was It Worth It?
For this site, yes.
Not because Astro defeated Hugo. Hugo did its job for years, and it gave us the stable static foundation that made a careful migration possible.
The move was worth it because the website now matches how I build software: plain-text content, static output, small client-side code, explicit contracts, repeatable tests, independent review, and a rollback when reality ignores the plan.
The final lesson is not “use Astro.” It is this:
Never start a website rewrite by asking how to rebuild the homepage. Start by asking what the old website is already promising.
Capture those promises. Turn them into tests. Then change the engine.
That is how I replaced Hugo without replacing the website.
